Originally posted by: happy medium
none..not to sure about tf2.
Never mind it uses one core..
http://www.hardforum.com/showthread.php?t=1272686
EDIT: 4870 is a good choice ..Good luck and let me know how it goes.
Wo, just saw a deal on Bestbuy, 224.99 for the same visiontek card.
Shipping + tax (dame jersey) comes out to 246, but I don't have to wait for Rebate.
Does anyone know if an HR03gt will fit on a 4870
Does it run cool on it's own,, and can I oc it a bit with the hr03
The HR-03 fits the 4870 and keeps the
GPU very cool. However, the rest of the card is boiling , having places with more then 100C, since the heatsink is very far from the PCB itself and there is not much flow of air over it. The biggest problem with this cooler is to cool down the VRMs that are reaching around 100C with the HR-03 provided heatsinks, on them. So I would stay away from this Thermalright for the 4870, because you are risking the cards lifespan.
Just play with the stock fan, making it spin faster when you are gaming and you can overclock the card and also keep it cool in the same time, having all the hot air exhausted outside.
I just looked at the OC stats for the card, and it's 2mhz per % increase in frames. Not bad. so Even if I get a fan to blow on the ram sinks No go?
The ram has nothing to do with overheating, as I think they are way cooler with something like the Hr 03 GT then they would have been with the stock cooler. Those 5 little VRM chips are the pain in the ass, because they heat up like crazy.
Maybe if you put on them some serious heatsinks and mount a fan there somehow, you might get their temperature in the safe zone. Try it and see. If they hit more then 90C , then you probably need to put the stock cooler back on the card. I have a friend that uses this cooler on his 4870, coupled with a very powerful Scythe fan ( 3000 rpm ) and the GPU never goes over 45 C in full load, but the VRMs are hitting 99C!!! with a couple of zerotherm heatsinks on them ( because he could not stick those that came with thermalright).
My advice is to try the stock cooler first and see if you like it. If you don't then put this on, but be prepared for higher temps in your case and maybe the VRM overheat.
I leave my p180 open most of the time.
LOL, I'm completely over making my computer case look good anything, this because I've more/less gone through all the computer nut "phases" from obsessive to apathetic 'visually' anyhow.
I mean,, no one can tell me 2gb DDR550 and a 2.9 opteron single core is not still sexy. LOL
Edit: ok i found the pictures of what the vrms are, I have an x1900xtx so, i'll just cannibalize the vrm sink from that one LOL.
I'm getting the Visiontek card, Am i still covered if I remove the stock heatsink?
