Problem:
When i access my seagate barcuda 80gb everything seems fine then all of a sudden win2k will lockup for 5 ~ 10 seconds, then unlock for 5 to 10 sec, then lockup again. This does this for a couple of minutes. After my puter is done freakin out, i am Unable to access that HD. I have to reboot to get the drive back.
The seagate is running off of a Promise PCI IDE controler card (ultra 66). I took off my seagate and hooked up my back IBM drive, and does the same excate thing. (so i guess its not the harddrive.)
Also when i copy files from the HD thats on the Primise IDE controller my system is unusable, It sucks out all the processing power from my PC.
The funny thing is that I NEVER had this problem before i upgraded my PC.
I was running:
650athlon
Asus K7M mobo
Win2K sp2
I upgraded to:
AMD2000+
Epox 8HKa+
Win2k sp2 (fresh install)
There are no cornflicks show in the Device Manager.
I am using a 80pin ide cable.
Under DiskDrives in the Device Manager the Seagate is reconized as a SCSI drive (ST380021 A SCSI DEVICE). is this abnormal??
Any suggestions would be great.
I hate weird problems that i cant figure out.
thanks
-neil.
I was running:
650athlon
Asus K7M mobo
Win2K sp2
I upgraded to:
AMD2000+
Epox 8HKa+
thanks
-neil.
