I am going be ordering a motherboard/cpu combo from mwave. have a quick question....
neil
236
I am pretty sure that i am going to get the epox 8kha+ w/ an AMD2000xp.
-does the motherboards/cpu bundles come with a heatsink & fan?
-(usually) if you buy just a cpu does it come with a heatsink &fan??
just curious.
thanks
-neil
oldfoof
1,127
I really couldn't tell you if the combo comes with a hfs .... it all depends on the vendor... some do some dont.
As for just buying a CPU if its a OEM then its just a bare Chip. If you buy a retail CPU then you will get a hfs.
Hope this helps Neil.
Oldfoof
Omer
203
neil:
look here for mwave's info on mb/cpu bundles.
I'm probably buying from them once the n-force 415's are available.
looks like:
Each motherboard bundle includes the following items:
Motherboard
Heatsink/Cooling Fan
Memory (Optional)
Assembly and Testing (Optional)
good luck !
piasabird
17,168
60
I dont know about MWAVE, but I ordered a Motherboard and BOXED Intel CPU from www.adamant.com/ and they mounted the CPU and the cooler that comes in the box for free. Sometimes it is cheaper to order the boxed CPU.
jsmckenna45431
1,418
I ordered a combo from mwave a while back and I believe it came with a HSF. I wouldn't plan on using it if I were you. They are pretty much as low performance and generic as you can get. I personally wouldn't use one if I palnned on keeping my CPU for more than a couple of days. I believe you have the option to upgrade the HSF and extend the warranty when you order.
Jeff
bozo1
6,364
The MWave bundles come with a HSF that is comprable (usually Coolermaster) to the ones used in the retail kits. Adequate if you aren't planning on overclocking.
