Hyperthreading and real time audio encoding
amddude
1,711
I have a PC that is doing a lot of real time audio processing and mp3 encoding across 8 virtual audio cables. Does it make sense to have hyperthreading enabled when I'm doing this?
edit: Thanks for the input everyone, I appreciate it.
dogen1
739
40
If you have a quad core with hyperthreading, and you're encoding 8 things at once, yeah. It might not make a noticeable difference, but you might as well keep it enabled.
tenks
287
There are very few cases where HT actually decreases your performance. So yea, have it enabled.
myocardia
9,291
30
Even in the rare case that performance decreases, it goes down by so little, it really isn't even noticeable. Like ~1% or less in most cases, compared to +25 to as much as +50% additional performance gained, in the software where it helps.
TheRyuu
5,479
14
Realistically you're unlikely to see more than a 25% performance increase with SMT and even that's basically the best case scenario AFAIK. The rest of what you said is correct though, the difference should be negligible to minor.
cytg111
26,671
15,973
I would guess so but not sure.. Why dont you run some tests and come back to us? :)
nerp
9,865
105
As long as you're not getting any lag od clipping, don't worry.
