ChrisRey3156
Just bought a Hyper 212plus with two lian li ball bearing fans at 1300rpm set up for push pull. I have 1 rear 120mm exhaust fan, 1 front 140mm intake fan, 1 side fan 120mm all around 1300 rpm to 1600rpm. It is 100 Fahrenheit degrees outside give or take and I'm running Prime95 so far for almost an hour and the average temps are 57 degrees celcius. The cpu is overclocked to 3.8ghz, how are the temps for that? At night when it cools down and my room gets nice and cool I expect a few celcius to drop maybe around 5 degrees.
My ambient temp is around 86 degrees Fahrenheit according to my thermometer. So that would be about 30 degrees celcius.
Setup: Core i5 2500k. GA-P67-UD3 F3 BIOS Rev. 1.0. MSI Gtx 560 TI Twin Frzr II at 1000 Core clock and 2000 Shader clock and 2020 Memory clock with a 1.087 voltage. In a Aerocool PGS-V Case. Gskill Ripjaws 1600mhz 2x2GB.
