I just got a Hydor L30 pump.
I'm confused about how to get the front cover off.
The instructions show a picture but I can't seem to pull it off and I don't want to break it.
How is it attached?
I mean where are the "hooks" that keep the plastic on
that would help me know where to squeeze
I think I'm gonna have to use a screwdriver or somethign to force it.
because I can't seem to get it off with my hands
there are no hooks...just grooves around that are sorta like rails...it just slides out. you can probably gently use a flathead screwdriver and pop it off.
