- May 28, 2008
- 1,199
- 0
- 0
I have been battling a fairly new (less than two year old home) AC for our home. The system is a carrier system, which from what I am told was a bit large for the 2k sqft home we have (builder told us this as we bought the model - full of upgrades on the CHEAP!).
Needless to say here is a run down of the issues (mind you I am still under my 2 year warranty for my AC unit):
* April 1st - Compressor and drier filter in the outside unit replaced and system recharged
* June 23rd - More noises from the compressor. Techician came out and found that the previous technician may have installed the wrong compressor, put in 10.25lbs of coolant (system only requires 7.25lbs) and the system was running at near 600PSI, dangerous for a system like this to be running this high. He discharges the system to the right levels, recommends that a new TXV and drier filter be installed
* July 13th - TXV and drier filter replaced
* July 14th - AC not cooling, TXV leaking coolant. TXV at 10:00pm as we got home to find our system running full blast and it was 85 in the house, with it set to 76. Called the AC company and told them to get out here ASAP. They were nice enough to send someone out tonight - different technician
First question is, does a system take an hour to go from 80 degrees to 79 degrees at 11:00pm at night after I was told the system is good to go? Used to we would have it set to 77/78 and turn it down to 75 when we got home, which cooled down within 20-30 minutes.
Is leaking coolant into the vents good for those indoors like we were all night lastnight with it leaking?
What do I do here? I have contacted my builder on each issue (they open tickets) and am starting to get fed up here. I have had to take 3 days off in the last few months to get this fixed, and each time the issues get bigger and bigger? When do I call the system and dud and make them replace EVERYTHING (attic unit, compressor/coil setup, etc)?
What legal action (if any) can I or should I take? I have a feeling that my electric bill is about to shoot sky high for this past month, with a system working half assed and it being quite warm the last few weeks here in the DFW area.
Your help is greatly appreciated!
