htpc mobo help required
docp
hello all,
i have got this weird issue after change of cabinet.
previously it was giving intermittent issues like slow start up then slow bios navigation but today it is not starting or going till asus boot screen.
i have problem of no video output.
i tried shuffling memory,resetting bios,re wiring everything but no go.
monitor and cable is working.(i checked both on my laptop over VGA)
how do i solve this problem.??
pls help me with this.
thanks in advance.
CPU:amd athlon II X4 635
Motherboard:asus M4A 785 DM PRO
Memory:kingstone DDR2 800 2GB,TRANSCEND 2GB DDR2667
HDD(s):WD 500AAKS As Boot Drive and WD 1 TB EARS as data drive.
Graphics card(s)😱nboard
Sound card: yet to install(creative 680)
Speakers: creative A210
Gaming peripherals:
Optical drive(s): LG DVD RW
Power Supply:Corsair CX400
CPU Cooler: CM TX3
Fans: inbuilt NZXT Gamma
Case: NZXT Gamma
Keyboard: logitech
Mouse: logitech wireless
Display: LG 2040t LED
Operating System: Win 7 home premium
i understand,that mistake happened as i bought RAM at seprate time.
i will get new power supply but motherboard does get proper power supply and on starting power button,cpu and chasis fan start as usual.
only thing their is no vga output.
i will get new power supply tomorrow.
thanks for your reply.
did you try a video card?
I keep an old PCI card for this purpose.
also, is the board shorting out on anything?
thanks iron woode for your reply,
next day i took everything apart and rewired everything,i am noob when it comes to building rigs,i had not put copper screws on case to mount motherboard.after putting those screws and then installing mobo on that foundation.everything worked as it supposed.
only question i would ask is can i test motherboard?
any utility to test same?
thanks again.
