birthdaymonkey
- Oct 4, 2010
- 1,176
- 3
- 81
I use a Noctua NH-C12P with no fan in my GD05. The case fans (which I run at 5v) are enough to keep my G620 quite cool.
So do you think it is pointless to buy a low-power CPU and then use a video card to play games?
Something like a Silverstone GD05 isnt really a small PC. May as well just put it in an Antec 300 and put that next to the TV. It would cost less.
You could use something like this if you did not use a video card:
http://www.directron.com/mi100bk.html
This kind of case comes with only a 250 watt power supply. But this might be enough with a low power 35 watt CPU. If you have to have a big honking video card then just use an i-5 quad and a silverstone case. However, this kind of case is like $49.00.
CPU: Pentium G530 $50
Motherboard: ASRock B75M $73
CPU Cooler: CM Hyper 212+ $20 AR
RAM: G.SKILL 4GB $24
PSU: Corsair CX500 $30 AR AP (ends 7/2)
Video Card: MSI HD 7770 GHz Edition $117 AR
Case: CM Elite 430 $30 AR
So, essentially, it's a passive radiator? Neat idea...
I would imagine that in a small case, it gets just enough of an indirect breeze to effective without having to be completely passive. But yeah a big hunk of metal works wonders!
