Hello, I have been able to pick up some parts from various black friday sales and want to build a gaming PC within the next 1 - 1.5 months or so. I'm mainly building it for Diablo III and the upcoming Counter Strike game, but hope that it will last for a few years with minimal upgrades. After seeing the gaming with a HTPC article on maximum PC, I am considering putting my machine into either the Lian Li PC-C33B, or the Silverstone LC10B-E case, but would like some advice on the matter before deciding. Here are a few questions:
1. What am I giving up by housing the machine in either of those cases? Will they majorly inhibit future upgrades (I have no plans to run SLI, but that's always an option I guess in the future).
2. Do I need to worry about overheating problems if I use a HTPC case?
3. Are those cases particularly noisy? As I said, this case will mostly be used for gaming, but if I could set it up in my living room (my desk is right next to my HDTV) and use it as a media center then that would be fantastic! Obviously, if it was super loud then there would be a problem for watching movies.
Currently I have the following items purchased:
CPU: Intel Core i5 2500K LGA 1155 $150 @ microcenter
CPU Cooler: Cooler Master 212+ $20 @ microcenter
Motherboard: ASUS P8z68-V LX 1155 ATX $60 @ microcenter
*** I got this Mobo because it was $60 off at microcenter, but am not sure of the quality. Am I right in thinking that it isn't able to run SLI? That isn't a huge concern unless I decide to run SLI graphics sometime in the future I guess...
In the MPC article I see that they recommend the Asus Maximus IV Gene-Z. Would that be a better option for me? Newegg has it for $170. That would permit me to get a smaller case, but I'm not sure if it's worth the extra $100, etc.
Memory: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Produc...82E16820231428
SSD :
OCZ 120 GB Agility 3 $124.99 @ microcenter
OCZ Vertex 3 120 GB $179.99 @ microcenter
***I am only going to keep one of the SSDs, but wasn't sure which one was the better deal so the clerk at microcenter told me to buy both and return one later. Do you guys have any input on this? I looked at the Newegg reviews and am a bit concerned about the amount of freezing/issues that both drives seem to have. Maybe it would be better to return both and purchase a M4 or intel SSD?
These are the items I have not purchased, but am currently considering (not knowing a ton about PCs):
Videocard: SAPPHIRE 100312-3SR Radeon HD 6950 Dirt3 Edition 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready $259.99 @ newegg
http://www.newegg.com/Product/Produc...82E16814102945
Hard Drive #2: Western Digital Caviar Green WD20EARS 2TB $199.99 @ newegg
http://www.newegg.com/Product/Produc...82E16822136514
PSU: XFX Core Edition PRO650W (P1-650S-NLB9) 650W $89.99 @ newegg
http://www.newegg.com/Product/Produc...82E16817207014
Monitor: No idea. Ideally, I want a 27" monitor optimized for gaming
Case:
LIAN LI Black Aluminum PC-C33B $159.99 @ newegg
http://www.newegg.com/Product/Produc...82E16811112228
Silverstone LC10B-E $89.99 @ newegg
http://www.newegg.com/Product/Produc...stone%20lc10-e
***Ideally, I want a nice and small case, but I'm not set on one of these two (they were just ones I thought looked nice).
I would like to keep the computer under $1500 (including a monitor), but can go slightly over if needed. Any help with this build would be greatly appreciated! Please let me know if I am missing key information, etc. I'm looking forward to building this (almost as much as I'm looking forward to playing D3 when it's released!).
Cheers!
SSD :
Case:
Cheers!
