Ichinisan
- Oct 9, 2002
- 28,298
- 1,235
- 136
Yeah, I know where the options are, but it simply doesn't do anything.If I remember correctly, if I even try to save a profile with the slider at anything but 100%, it refuses to do it. It makes me wonder if something is really borked with my GPU driver's profile, and that I should probably just find out how to delete it and start over.
I have everything hooked up through a receiver, so wouldn't that be an issue? If I remember correctly, those sort of settings are usually controlled on a per-connection basis. The problem is that things that do and things that do not need overscan correction are connected through my AVR. I've run into this catch 22 in the past with other issues. :\
It's a global setting on my old KDL-52XBR2. Even TVs that treat it as a per-source setting will probably default to overscan all inputs except VGA.
