tsupersonic
- Nov 11, 2013
- 867
- 21
- 91
Toolkits for the HTC One are awful! I have tried a few and nothing really worked for me. I took the time to do everything manually, and learned a whole lot more
I know this is a fairly old thread but I want to revive it with some fresh information on how to fix this problem.
I encountered this error after running the rum runner program that helps you s-off an HTC One. I fixed it by using fastboot and running the command "fastboot oem writesecureflag 3". I also ran "fastboot erase cache" and I reflashed the recovery partition.
Doesn't that first command just get you back to S-on?
