- Feb 14, 2004
- 48,732
- 5,470
- 136
Thanks for the comprehensive writeup , will forward that to my collegues and see what their opinion is on the slate pros as an option for the thinclient
You manage redirection of the barcode scanners and usb devices to the terminal server session?
Ive been playing around with remote fx and video camera redirection etc on a window 8 to 2012ts lab and works well .
Did you ever test the camera redirection on these devices to a ts session?
thanks
The barcode scanners basically act as a standard HID keyboard - the scanner (CCD, laser, whatever gear is inside) translates the barcode font into text input, so the computer basically just sees it as typing. I haven't had any issue with any brand or type of USB barcode scanner I've tried yet - works great in RDP!
I have not tried camera redirection. I am interested in doing some vGPU stuff, especially with GRID cards, but don't have anything scheduled to try out at the moment. I am messing around with some RemoteApp stuff; I believe the Android MS RDP app has full support for that built-in:
http://blogs.msdn.com/b/rds/archive...-os-x-and-android-available-for-download.aspx
I am curious to see how 3D performance is. I'd also be curious to do a side-by-side comparison of RDP performance - I have seen some artifacts on the Slates from time to time, although the Wyse boxes have lag problems as well; the best experience I've had performance-wise is RDP off a a PC (at one site, we repurposed all of their aging XP machines as RDP clients, worked great!). But the Wyse boxes also have the ability to handle monitors of different resolution, do multiple monitors, have some extra acceleration & display optimization tools built into the software, etc.
