HP pavilion dv2020ca driver problems
polski
55
my laptop went into the shop for lcd repair and when i got it back i formatted and reinstalled different a os along with formatting the recovery partition. Used hp website drivers and all drivers installed except for "PCI DEVICE" which is the sound card. When i try to install the AUDIO drivers an error saying "Driver Installation failed: Could not find media for this device". Any suggestions?
cheesehead
10,079
Find the chipset, and if it uses integrated audio (likely), find the chipset manufacturer's drivers.
I had the same problem with a Soyo motherboard that was missing the audio (PCI) driver - it worked for me.
Jan 31, 2002
40,819
Post the vendor and dev IDs.
Should be in Device Manager - "PCI Device" - go to Details tab, and then grab the Device Instance ID.
PCI\VEN_xxxx & DEV_xxxx
Post those.
- M4H
Spikestryker
I have a Pavillion DV2020CA that is showing a coprocessor error in device manager.
The id is PCI\VEN_10DE&DEV_0271&REV_A3
If anybody can help please let me know. Thanks Mike
Lanyap
8,301
2,397
0x0271 Chip Number: MCP51
Chip Description: Coprocessor (nForce System Management Controller)
http://www.pcidatabase.com/search.php?device_search_str=0271&device_search=Search
Looks like you need a chipset driver. Did you have a problem with this laptop or reload/recover Windows? Or did it just pop up with an error one day.
If you are running XP you can get the driver from here:
http://h10025.www1.hp.com/ewfrf/wc/s...08715&sw_lang=
