Question How would an E5-2690 v2 compare to an E5-2695 v2
Shmee
8,313
3,177
The E5 2699 v3 CPUs I was looking at are going for around $45 or best offer.
Reactions: jamesdsimone
lakedude
2,778
529
None of these builds are for me, they are for people on very tight budgets who want to be able to try PC gaming so 500 is over budget.
I get that.
How are you coming on other parts/software? The CPU is only one piece and I would argue less important than the GPU for gaming.
I had good luck with Kinguin for cheap Windows OS.
Maybe a used 1660ti @ $100 or so for video? My laptop has a 1660ti mobile and for years it was the best system in the house. It is totally decent. We are spoiled now with a 3080 and a 4070 but those are obviously over budget.
I can send you a GT240 for just the cost of shipping... Might be able to find a 4850 if you are interested.
If you can afford an SSD please try to get one. SSDs are a huge improvement over spinners.
lakedude
2,778
529
Our GPU with by far the most hours on it was my son's GTX 1050Ti mobile. It served him well for years until they updated BeamNG enough that he couldn't run the some of the bigger maps, especially with traffic.
He is now running a desktop with an RTX 4070 which on paper is many times better than the 1050Ti. Specs wise the 4070 destroys the 1050.
Visually we rate the 4070 about 15% better than the 1050Ti. We spent a lot of money for a 15% improvement...
jamesdsimone
1,007
286
For the V2 the best options are the E5-2667 v2 and the E5-2690 v2, both less than 25USD. The E5-2687 v2 is a little more but all you get is 100mhz higher base and it is a 150w vs 130w so probably not worth it. I'm looking at Haswell/Broadwell too. The E5-2699 v3 has a lot of cores but not sure that would help in gaming.
jamesdsimone
1,007
286
Handbrake is said to make good use of 6 cores with diminishing returns on additional cores.
Unfortunately this is not a hard cutoff and helps us only a little because more cores do help, just not as much as the first 6.
I've done a lot of benching Handbrake. It seems to use 8 cores but none beyond that. I found the following. Note that I use very high quality settings much higher than you typically see when you see benchmarks online so not sure how mine compare.
My old FX8350 gives me 13-15fps with all 8 cores at 100%
i7-6700 19-20fps
E5-2695 v2 give around 35fps but yes you have to run 2 encodes at the same time to get a total of 35fps. If you do one, the CPU only runs at about 40% and get 17-18bfps. Mine never gets above 2.8Ghz.
W-2145 gives 40-42fps with all 8 cores at 100%
5900x gives 60fps with one encode and 90fps with two.
jamesdsimone
1,007
286
I get that.
I ended up grabbing a z420 f0r 150USD. It comes with Windows 10 and has a 256Gb SSD boot drive so that is covered. And with 64Gb quad channel it should be good. I have been looking at 1080ti and 1660ti's. RX580's are cheap too. They are all good budget GPU's. I actually have 2 4850's, 2 5850's, and 2 7970's form builds long past, a GT710 too I think. I know everyone has this mindset that you need to be running the lastest and greatest. You really don't. There are countless great games from the last 10 years that would play great on a budget build especially when you consider the modding community. If I was new to PC gaming on a budget, Far Cry 1 with 4k textures would be great fun.
Thunder 57
4,296
7,104
Oh man I love FC1 and 2. FC2 has a real starfield at night, not just random stars.
When we got the new cards with the raytracing I played RTX Quake which is just Quake but with better textures and raytracing. Looks tons better, especially the water.View attachment 98930
You really don't need ray tracing to make water look good. Check out this from HL2:
Look at the second image in DX9 vs DX8. DX8 looks like a turd, in DirectX 9 the water looks much better. This was possible only 20 years ago or so.
lakedude
2,778
529
A buddy of mine had me run CyberPunk with ray tracing off and it looked amazingly good. Many of the things I had been attributing to the ray tracing looked nearly as good with it off. Shadows and reflections were there and looked fine. No way I'd notice the difference during active gameplay.
19,219
A friend showed me Control screenshots with RT on. I was not impressed. The graphics didn't look anything revolutionary. RT is just a really bad gimmick. No harm in turning it on if your GPU can handle it but GPU buying decisions shouldn't be based on RT performance. Maybe not until DirectX is updated to include some next generation iteration of RT where one vendor doesn't have an overwhelming advantage in RT performance.
lakedude
2,778
529
I got a really smart buddy who swears by it. He talks about reflections in mirrors, windows and water really helping him to play a game. Like he can see around corners and get the jump on the enemy.
RTX Quake certainly looks better but I don't know how much of that has to do with RT. Don't know if there are other ways to "fake it" without using RT.
My other smart friend (the one who had me turn off RT) is all about AMD cards and does not think much of RT. He speaks of "faking it" looking darn good.
Based on my experience so far I agree with you.
I'll turn RT off on RTX Quake and see how different it looks. Maybe if it is RT or nothing then RT looks much better but if there is a suitable non-RT substitute maybe RT isn't that big of a deal?
19,219
Yes. From the 1980s till a few years ago, PC graphics were amazing and RT-free.
Most of the recent stuff looks good but there are equally good enough looking games from a few years ago not using RT.
In my opinion, HDR was a bigger thing than RT. Check out the Half Life: Lost Coast demo. Look at the lighting in that. Not bad for something that runs at a gazillion fps.
jamesdsimone
1,007
286
Anything interesting you have discovered from your experiment of running games on a workstation CPU? Which games have you tried so far?
So far I've only been able to test the W-2145 because I only have one suitable video card to test.
W-2145/4x16Gb DDR4 PC2666/RX6800XT/WD 1TB 770NVMe boot drive/2TB corsair SSD I get 61.3 Average, 44.6 min and 88.2 max fps at 1680x1050 when I benched Deus Ex Mankind Divided. That is with all graphics quality settings to maximum. Bumping to 1080, the frame rate drops so that is the graphics card limited at the settings I'm using. I need to pick up some others. I want to see how the E5-2695 v2 does. I have an old 5850 1GB in now so that isn't worth benching I don't think.
Here are benchmarks with an 8 core and 16 core V4/Broadwell. The E5-2667 V4 is 30-40USD on ebay. Not bad for e-waste.
Shmee
8,313
3,177
Looks like I can get an E5-2697A V4 for under $40. Looking at various v3 and v4 Xeons on Ebay.
jamesdsimone
1,007
286
E5-2667 V4 is much stronger and has AVX2 which modern game engines use. The V2 Xeon is only AVX and will be pretty slow due to its age.
I know but just curious. I didn't expect it to do any gaming. That's why I just threw in a video card I had laying around. I'm using it for Handbrake right now.
jamesdsimone
1,007
286
The V4's are the best when it comes to price/performance and 14nm vs 22nm for the V3's. If you want to step up to a skylake it cost significantly more. W-2145 goes for 110-120USD.
lakedude
2,778
529
RTX Quake with reflections turned off. All the new textures are there but the water looks terrible.
Thunder 57
4,296
7,104
A 5600(X) on AM4 is hardly the "latest and greatest". Also, you keep saying 64Gb of memory, do you mean 8GB?
Ha Intel listed that CPU at launch at 4115USD.
Who cares what they sold them at? Back then you needed to pay the Intel tax if you wanted more than 4 cores.
AVX2 would be great for that.
Then why have you been asking about V2's? When Haswell was suggested you said they were too expensive. Now you're talking about Broadwell?
