How will AMD's Zen single thread performance compare to Steamroller's ?
  • Zen will have greater than 30% increase in ST performance compared to SR
  • Zen will have between 20% and 30% increase in ST performance compared to SR
  • Zen will have between 10% and 20% increase in ST performance compared to SR
  • Zen will have up to 10% increase in ST performance compared to SR
  • Zen will be roughly equal to Steamroller in ST performance
  • Zen will have up to 10% decrease in ST performance compared to SR
  • Zen will have between 10% and 20% decrease in ST performance compared to SR
  • Zen will have between 20% and 30% decrease in ST performance compared to SR
  • Zen will have greater than 30% decrease in ST performance compared to SR
What suggests to you that it will be comparable to Conroe? Hope?
Yes, and the fact they need to increase IPC so they can lower frequencies to get a better watt/performance. I compare it to Conroe since Intel went from speed to higher IPC and saw a drop in freq. I am assuming the same will occur, since AMD has a limited R&D budget
So you expect 1.2x IPC at (2.6 ghz/3.7 ghz : base clocks for a10-7580k and your expected Zen) = 85% the performance of Steamroller.
Since AMD has a limited budget. Get a higher IPC design out, then work out the kinks in the next revision, make the pipeline longer, add HBM, etc. If it is 85% the performance at 50% less perf/watt it would be a good trade off. As many users say PC's have been fast enough for awhile for office and most users. Obviously we enthusiasts will suffer.
I hope for 125% performance of SR but I temper my expectations with AMD's past performance, which has been lacking the better part of the last decade.
