How will A10-5800k cpu run with a 7950 gpu?
WhiteboyFaa
8
Hello, i was wondering how a Radeon HD 7950 will run with a A10-5800K cpu (not using the integrated graphics)? I want to run 1080p and will be playing valve games, a bit of battlefield on medium-high graphics settings, maybe a bit of arma and crysis, skyrim etc... Also i was wondering if this would bottleneck my computer.
Durvelle27
4,102
It would be a huge bottleneck in CPU limited games. I have a A10-6800K @4.8GHz w/ HD 7870 and it bottlenecks pretty badly in most games (Crysis 3, BF3 MP, Far Cry 3, Tomb Raider etc.)
I wouldn't pair it with anything higher than a stock 7870.
A10-6800K @4.7GHz+HD 7870 @1200/1450
Stuka87
6,240
2,559
I am not 100% sure how well a Phenom II matches clock for clock against an A10. But with my 965BE at 4.1GHz, and my 7950 at 1100, the majority of games run great. The only game I have been CPU bound in is dual threaded games (ie: Blizzard games) and BF3. But BF3 will nearly peg out a 4.5GHz 2500K on 64 player maps.
WhiteboyFaa
8
Yes, and i've been asking around and someone said the A10-5800K would bottleneck cpu demanding games (as did you) and he said to pair up a FX-6300. My budjet was 700 800 dollars but i had to up some parts (GPU and CPU) and thats all i can get within the price range since i changed from a 7770 and researched and decided to go with the 7950.
Durvelle27
4,102
I would really suggest an i5 or 8320 but a OC'd 6300 would be fine and more than capable
WhiteboyFaa
8
Alright i guess i'll get a FX 6300 and oc it to 4.2 ghz. My friends were saying to get an i5 but if i get and i5 i wont be able to get a 7950 sadly. Thanks for all your help i appreciate it!!!!!
Durvelle27
4,102
Are you in the US if so you can find good deals on the 7950 for around $200 sometimes $189
Stuka87
6,240
2,559
Prices there should be similar I would think. But certainly shop around. You should be able to find a nice 7950 (MSI TF3 or similar) for a good price.
WhiteboyFaa
8
Thanks for the replies, and what motherboard would you recommend that is compatible with my cpu and gpu between $100-$120? The motherboard i had picked out isn't compatible with the FX 6300.
lehtv
11,897
74
FX-6300 would bottleneck a 7950 as well. To avoid bottlenecking my 7950 @1.1GHz, I upgraded to 3770K from from i7-920 @ 3.36 which equals FX-6300 at ~4.1-4.2GHz. Went from 40fps to 60fps minimums in Alan Wake and BF3 MP, for example.
I would pair an FX-6300 with 7870 at most.
WhiteboyFaa
8
So, your i7 920 is equivalent to an FX 6300 oc'd to 4.2 and it runs bf3 mp at minimum settings at 60 fps or it runs at a minimum of 60 fps? Would this motherboard be compatible?
ASUS M5A99X Evo R2.0 ATX AM3+ DDR3 AMD 990X 3PCI-E16 2PCI-E1 1PCI USB3.0 SATA3 GBLAN Motherboard
USER8000
1,542
780
An FX6300 will be fine. My mate has a FX6300 running at 4.3GHZ on a Gigabyte GA-970A-UD3 with a Tahiti based HD7870XT(only slightly behind an HD7950 and based on the same core),which is also overclocked. It is fine with all the games he has run on it including Crysis 3 and Skyrim.
He is limited by his motherboard lacking LLC,so I would go with the Asus M5A97 EVO instead.
PPB
1,118
168
Yeah, but the 6300 to 8350 doesnt require new motherboard.
Herpaderp.
