Originally posted by: NickelPlate
I just bought one (the superclocked version), haven't even had it a week and already running it at 625/1000. I'm really happy with the card and getting great performance with new games even with my aging 3.8Ghz P4 Cedarmill. Temps are getting a bit warm though, 71C with a 29C case ambient. Not sure what a "safe" temperature is.
Originally posted by: CaiNaM
mine gpu/shader is 648/1458. memory is 1Ghz (2000Mhz DDR)
and g80's gpu clock generator/crystal works in certain incremements.
following is a chart which shows the "set" speed and the actual speed:
"set" frequency.....actual speeds
from-to................core....shader
509-524...............513.....1188
525-526...............513.....1242
527-547...............540.....1242
548-553...............540.....1296
554-571...............567.....1296
572-584...............576.....1350
585-594...............594.....1350
595-603...............604.....1404
604-616...............612.....1404
617-617...............621.....1404
618-634...............621.....1458
635-641...............648.....1458
642-661...............648.....1512
662-664...............675.....1512
665-679...............675.....1566
680-687...............684.....1566
688-692...............684.....1620
693-711...............702.....1620
712-724...............720.....1674
725-734...............729.....1674
735-742...............729.....1728
743-757...............756.....1728
Originally posted by: MyStupidMouth
Hmm im alittle pissed at my card. My 8800GTS 640mb is at 621/1000. Had it like that for about a month and a half. Now for some reason it freezes when im using ATI Tools. ANy ideas?
Forceware version is 158.19 btw.
Originally posted by: defiantsf
Is the shader clock configurable by any of the tools? Or do you have to flash the normal version with Superclocked BIOS to mod that?
not at this time. shader speed is relative to gpu clock, as shown in the chart in my earlier post.Originally posted by: defiantsf
Huh? I already know how to overclock with rivatuner. the problem im having is when i use ati tool's scan it freezes at 621/1000 when it was stable weeks ago.
Well, RivaTuner didn't work with some of the other 100-series drivers that needed to be installed manually or with modified .inf, which is why a lot of people including myself started using ATITool to begin with.
As for why its locking up, check your temps. Its warmer now where I am and generally not uncommon for a previously stable OC to become unstable in the summer months. That ATI Tool scan really heats up the GPU....like 15-20C in seconds so I'd look there first.
