Originally posted by: CaptainKahuna
Originally posted by: JW310
Also, depending on how many LEDs you plan on hooking up, you may be able to get away with using a couple 3V lithium batteries such as these:
3V Lithium Batteries to power the circuit. These would help keep the size to a minimum. With using batteries, you'll probably want some sort of on/off switch as well.
A switch such as this one from Radio Shack would be a good way to put a switch on it. Just mount it somewhere where it won't be easily seen.
JW
After thinking for a while, I think I want to go with batteries. Do I put the 3Vs in series or parallel? It's been a while since I had physics E&M. Can you give me a break down of how many mA/VDC I need for each LED, in case I want to scale to more LEDs? How did you determine the resistor values? Thanks for the help JW, you're input is really helpful.
EDIT: Also, how long do you think those two 3Vs would last?
You would want the 3V batteries in series to get 6V from them. If you use the red LED's in your eBay link, the maximum current you want to put through them is 30mA. The 150 ohm resistors I used in my diagram will limit the current to each LED to about 27mA.
How it works is each LED expects 1.8-2.2 VDC (according to your link), at a maximum of 30mA. So with a 6 volt source, you want to pick a resistor value that will limit the current to something under 30mA while dropping ~4 volts across it. To keep from sending too much current through the LED, I like to pick a resistor value that will allow for slightly less current to flow.
So assume the maximum current you want going through each LED is 25mA. You want 4 volts across the resistor, so using ohm's law where resistance = volts/amps, you get R = 4V/0.025A = 160 ohms. Since 160 ohms isn't a very common resistor value, I picked the closest common value - 150 ohms.
If you wire the LEDs in parallel, then you just need to add another resistor/LED pair in parallel with everything else that's there. In a circuit, everything that's in parallel with each other is at the same voltage potential. So each resistor/LED pair wired in parallel will be using the same 6VDC provided by the source. Using the resistor values I provided, you want to add 27mA to the amount of current being drawn for each resistor/LED pair.
The amount of time that those 3V batteries will last depends on how many LED/resistor pairs you have hooked up to it. The power rating on those batteries is 540mAh, which I believe means that the battery is capable of supplying 540mA for one hour before it's no good (someone correct me if I'm wrong here). So that means that with one resistor/LED pair, drawing 27mA, the batteries will last ~20 hours. If you use two resistor/LED pairs, that will draw 54mA, meaning the batteries should last ~10 hours. If you want the batteries to last a little longer, you'll need to use bigger batteries such as AAA or AA batteries. Though, of course, that means needing to find a place to put them that won't detract from the flower.
As for using the flower itself as one of the conductors, that should work as long as you check to make sure it will conduct electricity well. However, you may have some problems trying to solder to it - some metals just don't take solder very well. Regarding the concerns of touching it, with only having 6V going through it, and especially if you're powering it with batteries, you shouldn't have any worries about touching it.
JW
