Originally posted by: slag
Originally posted by: Eli
Originally posted by: Black88GTA
I don't have another plug handy...I would buy another, but the one in there already looks pretty good. I did take a dremel with a wire brush and clean up the electrode some before reinstalling it. The gas is good - after the mistake was discovered, my coworker drained the regular gas, refilled it with the proper mixture, and continued running it on Saturday when it seized up. It has about 1/2 tank left, and the gas is ~3 days old.
I got a pretty good look at the top of the piston through the exhaust port / spark plug hole, and it looks relatively undamaged. I saw a bit of gouging on the side that passes over the exhaust port, but it doesn't look really severe. From what I can see of the cylinder walls, they look pretty smooth too. The piston froze up about 1/2 way down the bore, so I was able to get a look at the area where it stuck through the exhaust port, once the piston was out of the way. The part I can see looks OK... but I couldn't see all of it.
Unsticking it took very little effort, so I'm hoping that the damage was minimal (although there certainly was some damage done).
ANY gouging to the cylinder wall is "severe".
It should be as smooth as glass all the way around.
Can't compare 2 cycles with 4 cycles. They won't take half the abuse before dying.
A 4 cycle will run on as little as 50PSI of compression.
You would be lucky to get a blip out of a 2 cycle with 80PSI.
Most 2 strokes will run fine with a minimal amount of cylinder wall gouging. Notice I'm not talking about just scratches, but grooves cut in the cylinder wall either from piston seizure or rings breaking off. General rule of thumb, if you can start it, it will run.
Smooth as glass would be idea, but 2 strokes will take a hell of a lot of abuse before dying.
My hobby is jetskis and I've seen it all--water ingestion, improper warm up resulting in 4 corner seizure, lack of oil, fuel starvation, detonation, etc. You'd be surprised how well some of these 2 stroke engines run with deep grooves in the cylinders, half of the piston missing, etc. I also collect lawn boys which are single cylinder 2 strokes and they run as well also with grooves in their cylinder walls, half a piston ring missing, blown lower seal, etc.
If it were me, after unsticking the piston, spray some WD40 in there and take a piece of emory cloth to the cylinder to remove any high material. Wash it out well with kerosene when done and use a clean rag until its spotless. Run it @32:1 oil ratio with some good opti2 2 stroke oil for a few tankfulls and then go back to normal ratio.
