How to unlock Pipelines and Vertex Shader on a 6800 (nu/le/gs)
2Xtreme21
7,044
Hmm, your link does not seem to work. Are all of the descriptions for the shaders "N/A" as in bits 04-07 and 14 onward in my picture? There should, ideally, be one bit in the 08-13 range that has a description of "Vertex Unit x" and has "disabled" instead of "enabled" in the third column. If yours is not shown in the same manner as mine, I would really like to see it. Try uploading it here and linking that.
2Xtreme21
7,044
Wow that is REALLY odd. There's only a few things I can see: one, the 6800GS that you have uses the NV-41 core. That means any extra pipes are hardware masked and cannot unlock. Second, your 6800GS is 128-bit and I've never seen a 128-bit GS. If I were you I'd set it back to default in the NVStrap menu since right now you're only running on 8 pipes and 4 shaders... and it SHOULD be 12 pipes and 5 shaders.
Sorry I couldn't be of more help.
wwolf226
4
work for me with the vshader but got pixelized with the pipes... i have the evga6800gs .. gonna try to update the drivers and re-try.
TheOnlySuperdog
11
I'm having the exact same issue as kotix. I have the AGP card with NV41 core. NV41 has 12/5, but this XFX 6800 XTreme is only allowing 8/4. No luck unlocking, and I get the same N/A as kotix posted.
I've read that the NV41 is a pci-e native chip, and a bridge was needed to make this an AGP part....I wonder if they were able to lock it through that bridge? I dunno. Was really hoping to get 12/5, but am satisfied with the performance for the price I paid.
However, if anyone has learned how to overcome this obstacle, please let me know!
SD
