how to timedemo in Doom3?
mrwxyz
334
Originally posted by: Leon
Here is a comparison between P4 2.4 and P4 1.8 (downclocked)
P4 2.4 (Northwood)
1Gb
6800GT (420/1130)
High Quality
1600 x 1200 0xAA 8xAF - 50.3fps
1600 x 1200 2xAA 8xAF - 47.5fps
1600x1200 4xAA 8xAF - 40.1fps
P4 1.8 (Northwood)
1Gb
6800GT (420/1130)
High Quality
1600 x 1200 0xAA 8xAF - 38.1fps
1600 x 1200 2xAA 8xAF - 36.7fps
1600x1200 4xAA 8xAF - 33.5fps
So, if you have slow cpu and powerful card, might as well turn everything on :)
thats pretty cool that the d3 engine runs so well like that.....they really didnt lie, u dont need the latest and greatest to play this game!
NYHoustonman
2,642
Originally posted by: TheSnowman
bastards say all the ebs around here won't get it until wendsday morning.
Same ><. I'll be making a mad dash to the local gargantuan mall, checking EB Games there just to be sure, CompUSA, and BestBuy (whose website now says 8/4 as well ><).
jiffylube1024
7,430
Originally posted by: ScrewFace
I just came back from the future (2008) and tested Doom3 with ATI's new Radeon XIII800 XT 2GB GDDR5 with 64 pixelpipelines running at 1000 MHz and RAM at 2400MHz (4800MHz).
I got 573 fps playing Doom 3 at 2048x1536 with 64xAF and 32X AA. A little low for 2008 but then I was only running a Pentium6 20GHz overclocked to 28GHz and 10GB of PC16000 QDR3-SDRAM.:beer:;)
That's a pretty weak overclock for a P6 20Ghz (Intel model number: Pentium 50,000), IMO. I got mine up to 33 Ghz ;) .
MDE
13,199
Athlon XP 2500+ @ 3000+ (200x10.5)
Abit NF7-S 2.0
1GB HyperX RAM
BFG GeForce FX5900 XT @ 450/736
Running @ 1024x768 medium detail I get 30 FPS
FlasHBurN
1,349
Try adding an additional '1' (e.g. timedemo demo1 1) to enable precaching textures, that will eliminate the need to run each timedemo twice.
xcript
8,258
1024x768/medium detail: 2148 frames rendered in 76.5 seconds = 28.1 FPS
XP1800+ @2GHz/1GB PC3200/FX 5900XT
Ouch.
Rankor
1,667
you should update your sig then
LOL :laugh:
mb
10,233
640x480 low detail, all advanced settings off = 27.5 FPS
P4-M 1.7Ghz
512mb pc2100 ram
32mb GeForce4 440 Go
I've got a new computer on order right now :D
Soon to be:
Asus A8V
AMD 3500+
1GB Corsair 2-2-2 memory
evga 6800NU
I can't wait!
Jul 23, 2004
59
Something's not right. I ran it on my P4 3.2 with 2 GB Ram and a 9800 Pro Default settings @1280X1024 Medium Detail and my value is only 25fps! what the heck gives?!
Childs
11,313
7
Originally posted by: nitromullet
Where is everyone getting this game from!?! I know some people got it from Best Buy in Sat, but supposedly they stopped that. I checked around a number of stores around Atlanta, and nothing...
Also, D3 hit the P2P networks over the weekend.
nRollo
Banned
Jan 11, 2002
10,460
The deal is ATI, especially last gen ATI, is teh stinxorz for Doom3?
Bucksnort
1,062
Do you have aa and af set to application preference? And run at 1024x768.
1ManArmY
1,333
Make a decison on how you want to AA or AF to be implemented. ATI card utilized the control panel set AA and AF is you check the application preference then the AA &amp; AF will use what is set in DOOM III set-up otherwise if the application preference is left unchecked then it will use those settings in the ATI control panel.
Jul 23, 2004
59
ok.. on 1024 medium detail, its 43fps... alot better..
for arguements sake, on 1024 high its 40fps.. not too bad of a drop.. and this is all on stock 9800 pro speeds.. no change at all
Jeff7181
18,368
11
Originally posted by: sep
Originally posted by: gururu
post some FRAPS benchies. how's your 9800xt doing?
Yes, I'm curious too (me got 9800pro 128).
My 9800 Pro 128 does great at 1024x768 on High. I don't use AA or AF because well... I don't notice the difference while I'm playing... so much of the scenery is dark that you don't notice the jaggies, and there's nothing really ever that far away that you see much edge crawling. While playing at those settings I spend the majority of my time above 50 frames per second.
I'm VERY impressed with the amount of shadowing that's done without it being a slideshow.
gururu
2,402
P4 1.6@2.3
512mb RAM
9700pro
1024x768
High Quality: 35.1
High Quality/16x AF(quality): 28.3
Medium Quality: 38.2
Medium Quality/16x AF(quality): 29.6
1280x1024
High Quality: 25.0
High Quality/16x AF(quality): 19.5
Medium Quality: 26.9
Medium Quality/16x AF(quality): 20.4
all scores from second bench
gururu
2,402
i saw it on a similar system yesterday, and it was a lot smoother than 25fps. I am currently running the 4.7s
Robor
Something just isn't right that my settings are that low :( You guys running those Beta Catalyst 4.8 drivers?
Your latest numbers don't look that bad. We have a very similar setup except I'm overclocking my 9800P and you're only 4-5 FPS behind me at the same resolution/detail level.
I really wish I could've picked up a BFG 6800 GT/Ultra to run 1600x1200 4x/8x though. Even if it's a slideshow (20 FPS on my rig) have a look at the timedemo at 1600x1200 - even on high with no AA it looks *amazing*!
Edit: Oh, I'm on WinXP Pro and 4.7 cats.
Jeff7181
18,368
11
9800 Pro at 395/360... Barton @ 2.48 GHz... 1 GB PC3500 CAS2 RAM... Fastwrites and Sideband addressing enabled... 8XAGP of course
1024x768 @ Medium - 48.1 FPS
1024x768 @ High - 43.6 FPS
1024x768 @ Ultra High - 34.8 FPS
1280x1024 @ Medium - 32.0 FPS
That's all the testing I've done for now...
Apr 17, 2003
37,622
guys, can one of you all do me a huge favor? can someone bench with 512 of ram and use the same rig to bench with a gig of ram?
Jul 23, 2004
59
Jeff.. I tried ultra rigtht now.. interesting my drop from High (41fps) to Ultra (38fps) wasn't much. I'm willing to bet the bank that's due to my 2GB of RAM
Jeff7181
18,368
11
jeff: What kinda rig do you have? How do you disable anthroscopic? Ithought high setting in doom automatically enabled it?
I didn't read the post all the way through, I guess I have 8X enabled cause it's set to application preference in the drivers. Although... I thought I noticed a performance hit when I set it to 4X manually... I'll have to double check that.
*EDIT* Rig details are in another post... if you want more details I can be more thorough... bout the only thing I didn't mention is my Raptor and Audity 2 ZS.
