How to tell fan direction
Status
Not open for further replies.
andrewboon
105
I'm trying to setup a push-pull configuration with my heatsink and I am wondering how to tell which way the fan is blowing. Thanks
andrewboon
105
So it's possible for me to look at a fan that's rotating at a rate of two thousand revolutions per minute (33.3 revolutions per SECOND) and determine that?
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Fans don't start or end at that speed. I assuming you're in the same room and in control of the computer at the time. Not to mention, having a modicum of intelligence.
Bryf50
1,429
51
I've always used this rule. The side that has the plastic connected from the frame to the motor in the center is the side that air blows out of.
GoStumpy
1,211
11
Yeah this is nearly an epic fail thread.... Seriously? Taking the time to write a post of it on here takes 5x longer than just googling it, and saves a LOT of embarassment.
Turn it on unmounted and see which end blows at your hand.
Look for arrows on the casing
It will always blow towards the structural plastic side
OR.... Common sense?
Zorander
1,143
Test the fan on the case chassis. Generally the intake side is cooler than the exhaust side (kinda d'uh but often not obvious to many). I can do this with my 800rpm fans so you should have even less trouble with your 2000rpm fans.
lehtv
11,897
74
The fan blades are curved, convex (outward curved) on one side, concave (inward curved) on the other. Air will flow from the convex side to the concave side.
RavenSEAL
8,661
No worries OP, took me a few minutes to figure it out as well my first time putting a case together, lol.
aigomorla
21,070
3,575
B4 this gets out of hand i am locking it..
Incase you want to know direction, look for the frame, if it has a plastic bar going across it, that side is the side it blows out.
This thread is now LOCKED b4 a bonfire which the water in my computer cant put out starts.
Cases and Cooling Moderator
Aigomorla
Status
