- May 23, 2002
- 16,928
- 8
- 81
Since the cost of gas is continuing to rise, I was browsing through the gmability web link and came across this article that has some neat thigns on how to get better gas mileage and other benefits.
So I just thought I'd pass it along for anyone that might be doing things that are costing them money by eating up their gas mileage....
Tips from Opel on Saving Fuel and Reducing Running Costs
Ten practical hints on how to drive more efficiently and protect the environment
RUSSELSHEIM (April 16, 2002) -- Modern automobile technology has made great strides in reducing fuel consumption and CO2 emissions, but handling the car correctly is also one of the biggest and often insufficiently explored factors in saving fuel. Martin Holzhofer, who is responsible for the Eco model program at Opel's International Technical Development Center (ITDC), is convinced of this: "Everyone who puts even a few of these important hints into practice will reap the benefit in hard cash next time the car is filled up. For example, useful tips for this purpose can be found in every Opel vehicle's user manual." By making sure that their cars are well looked after and by adopting a suitable driving style, it's easy for each and every driver to personally squeeze the greatest mileage out of every drop of gasoline.
As far as the car itself is concerned, an efficient driveline is essential, and this calls for regular routine maintenance. The car's rolling resistance must not be allowed to increase, which means that it is also important to check the tire pressure because low tire pressure causes increased rolling resistance and thus costs more money in two areas: for fuel and due to increased tire wear. Those who are determined to get the maximum fuel economy may choose to pump the tires up to one or two tenths of a decimal point above the specified pressure in bar. Another useful tip is not to carry too much unnecessary ballast around with you in the car's trunk or load area. A 100 kilogram load can result in increased fuel consumption of up to 0.5 liters per 100 kilometers in city traffic. For further fuel-saving success, don't leave the roof rack in position when you don't need it ? everything that worsens the car's aerodynamics also causes it to consume more fuel.
Turning off electrical accessories such as air conditioning, rear window de-fogger or additional lights when not in use also results in fuel economy because these services increase fuel requirements.
While on the move, the golden rule is to look well ahead and maintain steady speeds. Unnecessary accelerating and braking not only cost fuel but fray the nerves as well. Accelerate briskly but not aggressively: it's actually better to press the accelerator pedal down farther in a higher gear than to run the engine up to high revs. Shift up to top gear as soon as you can. One can often drive in fifth gear from 50 km/h. it is generally advisable to remain at a low rate of revolutions per minute (between 2000 and 3000 rpm) whenever possible. Shift to the top gear as son as you have reached the desired speed. Using only 75 percent of the vehicle's top speed is also economical. It results in fuel savings of up to 50 percent with only a negligible loss of time.
When the cold season of the year comes around, don't warm the engine up with the car at a standstill. Instead, drive off immediately after starting the engine and let it warm up to operating temperature while driving within a medium rpm range. Switch off the engine for stops of one minute or longer. The engine burns fuel even while idling. The automatic fuel intake shutdown while coasting, while driving down a hill or while braking, provides another means of saving fuel. Therefore don't step on the accelerator while coasting and don't take the vehicle out of gear, instead make use of this opportunity to save fuel.
Use of the "sports" option and unnecessary manual shifting lead to increased fuel consumption in vehicles with automatic transmissions. The engine is operating in an economical way in the "D" gear, which can almost always be used. Gentle, even pressure on the accelerator pedal causes the transmission to shift earlier to an energy saving gear.
Ten Ways to Save Fuel
1 Don't warm the engine up with the car at a standstill, instead drive off right away.
2 Drive at steady speeds, looking well ahead and use fifth gear (or the car's top gear) for all regular driving.
3 Don't step on the gas pedal while coasting and remain in gear. Switch off the engine if you have to wait for a long time.
4 Accelerate briskly and shift up early.
5 Use only 75 percent of the vehicle's top speed.
6 Avoid full acceleration and kickdown with automatic and automated manual transmissions and apply pressure to the accelerator pedal in a restrained manner.
7 Check tire pressure regularly.
8 Take off the roof rack when not in use.
9 Remove unwanted objects from the car. Shut down unneeded electricity consumers when not needed.
10 Service the vehicle regularly.
