B blahblah99 Platinum Member Oct 10, 2000 2,689 0 0 Sep 17, 2001 #1 if i want to run a counter-strike server as a system process (so it runs no matter what user is signed on) in w2k, how do i do that?
S syf3r Senior member Oct 15, 1999 673 0 0 Sep 17, 2001 #2 could probably use an app called firedaemon. do a google search on it... it's free... -syf3r.
P PrincessGuard Golden Member Feb 5, 2001 1,435 0 0 Sep 17, 2001 #3 Or, if you simply can't stand using 3rd part software, you can use SRVANY and INSTSERV from the Win2k Resource Kit.
S syf3r Senior member Oct 15, 1999 673 0 0 Sep 17, 2001 #4 yeah, that too... although i think the reason i ended up using firedaemon was because i *tried* using srvany first... -syf3r.
