How To Read Your Power Supply Voltages
Discussion in 'Power Supplies' started by theAnimal, Jan 17, 2009.
Thread Status:
Not open for further replies.
  1. mikeford
    mikeford Diamond Member
    Jan 27, 2001
    5,100
    I've got a box full of old PS, and I would like to quickly weed out the bad ones. I've got three testers, Power and Cooling with a resistor pack and single led, cheap 10 led tester, and deluxe version with a nice backlit display that shows numerical values for 6 things. Using this last tester, some PS have been clearly bad, no start, or voltages too low (like less than 4.7 on the 5v).
    Should I use the voltage ranges in your earlier post, or should I be making some adjustment for no or little load?
    I do plug in a hard drive if a PS looks basically good.
    Most of these are for OLD systems, 20 pin ATX etc., any adjustments on that basis?
    Thanks, good thread.
  2. theAnimal
    theAnimal Diamond Member
    Mar 18, 2003
    3,828
    23
    The range is the same regardless.
    No, out of spec voltage is bad for any system.
  3. Marcuf
    Marcuf Banned
    Oct 9, 2010
    19
    All of this information is well and good Ernie, but I've looked over all your blog entries visible without going to archives and it seems every one is either 100% about the iPhone
  4. PreferLinux
    PreferLinux Senior member
    Dec 29, 2010
    420
    I think it may be worthwhile to add a comment that 12 V DC is not dangerous. i.e. if you touch any live wire in a computer along with, say, the case (so you are grounded), you won't feel anything unless it is a +/- 12 V wire (yellow or purple), and even then it would be very slight, if noticeable, and would definitely not be harmful. But it is still a good idea to be careful.
    Also, as the case is grounded, it is possibly a good place for the ground probe.
  5. cpul
    cpul Junior Member
    Feb 18, 2011
    hai.
    I have some questions
    My computer often die suddenly, what power supply can cause this?
  6. theAnimal
    Mar 18, 2003
    3,828
    23
    Probably best to start a new topic & provide more information.
    Either a defective PSU or one that cannot provide enough power could cause crashes.
    Edit: Welcome to Anandtech! :)
    Alice89 likes this.
  7. rayed
    rayed Junior Member
    Nov 4, 2011
    I am always suffering with this problem but know i will try this.
  8. suncare
    suncare Banned
    Feb 15, 2013
    17
    Thanks. To act now. Take care of my computer.
Thread Status:
