How to pan fry a 8 oz. new York strip steak?
Oct 25, 2006
11,036
11
Touch test isn't dumb. It works perfectly. The point is that you get used to your own touch.
So, giving a extremely subjective method, which isn't even a good test when you are in the know, is good advice to give someone who obviously doesn't cook steaks on a regular basis?
Drako
10,697
161
Touch test is really really dumb. Every cut of meat and everyone's hands are different and is an extremely subjective test.
Thermometer gives you a objective measure of when a steak is done.
Poking a steak with a meat thermometer is really really really really dumb. :colbert:
Good job letting all that delicious juice out of your steak. :)
CoPhotoGuy
452
Your opinion is noted, however incorrect it might be. Touch test works perfectly. I can even get newbies to get it right. I'm not poking holes in my steak until it's ready for the knife.
Oct 25, 2006
11,036
11
Stupid. Have you ever made a steak before? Is a steak somehow a water balloon that lets out all its moisture the second that you pierce it? Does a steak hold all of its moisture in a single 1x1 mm square of meat that suddenly all disappears when you make a hole? Considering you're cooking meat on a 500+ degree surface, how much moisture do you think is lost due to the fact that water boils at 212 versus poking it with a tiny stick?
Also, how is a touch test accurate? Does your finger suddenly know if its touching a particularly meaty area of the meat versus a fattier area? Because they will feel completely different. How about different thicknesses? A thick steak will feel completely different than a thing steak due to compression differences.
Stop cooking based on what you "feel" and cook based on objective fact. Your assertions that 1) the poke test is a good way to judge meat doneness and b) that poking a steak causes significant moisture loss has been disproven time and time again in modern cooking.
How is a subjective test better than a objective test. A steak will ALWAYS be medium rare at 130 degrees and ALWAYS be medium at 140. There is no wiggle room.
MongGrel
38,466
3,067
121
I saw Steak Wars coming :biggrin:
:colbert:
Drako
10,697
161
Wow, someones panities are in a twist. :biggrin:
Phynaz
10,140
819
Use a pan thermometer and heat pan to 450. Sear steak. Let rest 8 minutes per pound.
Oct 25, 2006
11,036
11
Sick of people who think they have any idea of what they're talking about when it comes to cooking meat and propose dumb methods of cooking.
IMO sous vide is always the best way to do steak. Takes a bit more effort, but once again, perfect every single time.
KeithTalent
Administrator
Nov 30, 2005
50,231
117
Meh, I cooked steaks to proper doneness in restaurants for years using nothing but my hands and a pair of tongs. /shrug
KT
MongGrel
38,466
3,067
121
I did not, so I use a thermometer.
I used to broil them fine without one, but just makes doing it right easier.
Drako
10,697
161
Uh oh, another sous vide steak guy. :biggrin:
Drako
10,697
161
KT
Same here, but I guess it's not an "exact enough" method for the science experiment guys.
Remobz
2,564
37
Just wanted a simple easy way to pan fry a steak.
The steak is about 1 1/4 to 1 1/2 inches thick.
I think I might take it out the fridge about 40 minutes before I cook it. Rub it with steak seasoning and peanut oil then put it in a hard bottom pan (non stick) for about 4 minutes on each side. Flipping only once or twice.
The frying pan will initially be left on the stove top for 5 minutes at HIGH heat before the steak is placed in it.
I never done this before and don't want to over complicate matters here.
Hayabusa Rider
Admin Emeritus & Elite Member
Jan 26, 2000
50,879
4,266
You had your best answer in the first response :whiste:
:D
WaTaGuMp
21,207
2,506
On Master Chef Jr this evening, they were cooking filets, guess what, they showed one girl checking them with a thermometer. I don't use them myself, but might try one down the road.
balloonshark
6,546
3,006
When I heat my cast iron skillet to high heat it goes above the smoke point and smokes me out of the kitchen. Do you really need high heat to sear a steak? Or is heating the skillet just below the smoke point fine?
Remobz
2,564
37
Guys I have a new question.
When picking your steak (whether it be New York or Top Sirloin or Ribeye) what type of grades do you look for?
Do you look for black Angus? prime? grade A? etc. etc.
WaTaGuMp
21,207
2,506
Depends on your budget. Prime is the highest, then choice. I get choice filets from Costco. Then you get into higher end beef like Angus and Wagyu, not sure if those have things like prime etc.
