VirtualLarry
- Aug 25, 2001
- 56,587
- 10,225
- 126
Originally posted by: martensite
FWIW, here is a timely (hehe) and personal anecdote from last week regarding my friend's desktop.
It's a mid-low range PC: 3700+, A8N-E, 512MB (originally 1 GB, but one stick died), 160 GB (~35% free space), Asus/Pioneer DL DVDRW; in fact almost identical to my old system since both of us purchased the components at the same time.
I am trying to burn a 4.7GB TDK 16X DVD+R with a few 700MB divx filesso I can take them home to my PC. I know that the media is fine, I've never had a single bad burn from more than 40 samples, but on his PC, it failed repeatedly at 16x. 3 discs ended up as coasters. Buffer underrun protection was on, tried another DVD+R(LG) etc, but with the same result. I thought his dvd writer was screwed and recommended that he replace the POS and that he should have bought a BenQ 1640 in the first place lol.
Then I thought I'd analyze his HDD and hell, the XP defragger showed more red than a Commie rally. He had not defragged in more than a year lol. Lots of free space, but ridiculous amount of fragmentation too. Ran Ccleaner, downloaded and ran the trial version of Diskeeper 2008 and defragged... took quite a while. Tried to burn again and it burned perfectly fine! Apart from defragging, i did not change one thing.
So, I dont think defragmentation is unnecessary at all. I think it helps quite a bit. No reason NOT to defrag, especially when it doesnt require much effort anyway.
So you're claiming that the burn-proof feature of the drive was disabled/non-functional, until you defragmented the HD? I don't buy the story, that's illogical.
A more logical solution is that a media compatibility issue exists between his drive, and the media that you brought over.
