Jeff7
- Jan 4, 2001
- 41,596
- 20
- 81
That magnetic drive needs to be spun up to 2000rpm though. That takes energy to do. You will always get less energy out of that spinning disc than you put in, unless you figure out some way to eliminate friction.If you had a magnetic drive that spins at 2k and slows down over an exended period of time due to centrifical force, then it could be creating power even when coasting just from the magnetic field created. Or you could keep it going at a steady rate buy using pulses instead of constant power.
That's all a flywheel does - you spin it up, and the energy is stored in its momentum. As you draw energy from it, it slows down. The energy gained, magnets or no magnets, is less than what you put in.
Can't. They're not perpetual, at least not in the "perpetual motion" sense. Earth receives many MANY terawatts of energy from the Sun, constantly. You get uneven heating, which leads to turbulence. You've also got heat from inside Earth, a bit from radioactive decay, and a lot just leftover from its formation.Think of the perpetual movement of waves in the ocean.
Orders of magnitude. Earth is huge, and it's made mostly of rock and metal. The thin film of water that covers part of the surface is a very small portion of that, and the human population is far less than that.Does moving ships back and forth through the waves make the earth slow down? Same goes for wind turbines. How comes the earth's orbit does not decay when we harness the power?
A freight train will slow down when it runs into a small swarm of 200 fruit flies.
Yes, you know...that stuff.Basically, yes, waves (really tidal forces) are slowing the Earth's rotation. This is a measurable effect, and you can also see it in the recession of the moon's orbit. Do ships and wind turbines change the Earth's rotation? Sure. But the Earth has a *lot* of angular momentum...the effect is very small.
Very large earthquakes also change the earth's rotation.
Thermodynamics and conservation of energy, they are a thing.
Eventually, Earth's rotation will slow until we're tidally locked with the Moon, so the same side of Earth will always face the Moon.
