Originally posted by: mrSHEiK124
15, I usually weigh myself at night
Ok, at 15 yrs old you're just likely coming into the phase of maturity/pysical developement where you will start to gain more quickly oif you lift. if you weight lift. You bodies production of HGH (humane growth hormone) is on the upswing.
Drop the fat crap in your diet, some is good, but loading up on fast food crap is no good. Period. You gonna just crap out that useless stuff. Focus on protein and complex carbs. There are many protein shake products available and some do taste very good. For weight gain I prefer to eat smaller amounts, but eat more often.
Look, no matter your weight if your stomach is bigger than your shoiulders you look like sh1t. The other way around makes you look more athletic/powerful. Even if an optical illusion.
Weight lifting: You'll have to experiment a bit. Everyone's body is different, and will respond diferently to different excercises. For example incline bench just doesn't produce much in the way of results for me. I'm 46yrs old and have been lifting since I was 13yrs old, so I know how to do the excercise properely. It's just that my body doesn't respond well to incline BP.
Also, pay attention to techniqe & proper warm-up. Don't over-do it at first. Down-time due to injuries is no help. I prefer to work-out at home. I don't like the "social" aspects at gym's. I don't want to lose my focus from social chatter or unsolicited advice etc. But a partner can be a good thing (spotting etc) if they are serious.
Excercising each muscle group 3 times a week may be too much (overwork and very little gains). Many say 1 time a week is best - doesn't really work for me. I need 2 times a week per group to see quicker results. Some times I may go a little lighter on one of the 2 weekly mucsle group workouts if I feel I'm overworking it a bit (sometimes after moving up in weight or reps for excercises). With experience you'll be able to much better "feel" your body/muscles and adjust.
My schedule: Mon & Thurs- chest, shoulders & tricepts. Tues & Fri bicepts, legs & back (lats). This is sort of a push/pull type regime and I still it's very effective. Like others have said above, forget the fancy/trendy sh1t. (1) You're a beginner, no need for complicated stuff as if you're trying to break the world benchpress record, (2) tried & true stuff will definetly gain weight, new trendy crap may not.
For chest start with regular benchpress (other than warm-up set limit reps to a max of 8, but experiment, again diff peeps respond diferently to reps/sets combo's). Later add pectoral flys, &/or dips.
Shoulders. Start with shoulder presses, either barbell or dumbell. I prefer dumbbell. Can also add upright rows, cleans or lateral fly's etc
Tricept. Skull crushers, benching with hands very close on a cambered curling bar etc.
Legs. Squats are a must. Can also add sissy squats, leg extensions etc.
Deadlifts are great for gaining weight (will also increase your forarms and other mucsle groups such as traps & lats).
Bicepts: Arm curls. Barbell or dumbell or both. preacher curls. Will likely get "thicker" bicept area with a cambered curling bar. Also reverse curls for outside of bicepts and upper outside of forarms.
Lats. Bent-over rows (dunbell or barbell), lat pull downs (there are different variations, may want to do two - hands wide with palm down, hands close with palm up).
You can also do forarm curls (barbell or dumbell) or use some kind of "grip excerciser" device. I once knew a guy who performed an "unusual" excercise for the forarms which was very effective. He'd take the daily newspaper, spread a sheet of it on the dinning room table and use one hand at a time to "crunch" it up into a ball.
Abs & calves - not much in those for weight gain so I won't comment.
Oh, the amount of rest between sets is important. Here again, different folks get beter results with different amounts of time. And different excercises seem to respond better (for me) with diiferent amonts of time. The shortest rest period between sets I use is about 2-2.5 minutes. Others more like 4 minutes (when heavy on bench.squats & deadlifts). You'll have to see what works best for you.
If you wanna run, I prefer to do windsprints instead of running several miles. I've done both (10K's, triathlons etc), but feel windsprints may actually help build a little muscle (legs, calves abs etc), while long runs just slim me down.
Finally, I find it helpful not to focus on my weight or any measurements (other than waist size maybe). If you lift heavy weights, and focus on increasing the amount of weight you can do in excercises, the other stuff will come. No two ways about it.
I'm 5'11+ and 185lbs.
