I am going to make an attempt at making my own usb connections using .1? female crimp pins and 5 pin molex connectors. Is anyone here familiar with this procedure?
The two biggest questions I have are:
1) Can I use solid wire with these pins or do I use braided wire?
2) How far down do I place the wire in the crimp pin? If I place the wire too far in the pin then I risk the wire interfering with the male connecting pins on the mobo.
Any information would be great. I would also appreciate any links to some sites that may have a how to procedure on it.
Thanks,
Pokey
Thanks,
Pokey
