Originally posted by: ed21x
if you want good structural rigidity, cut toothpicks in half and proceed to use half sized toothpicks.
Ah, and a few capitalizations. 😛
Ah, but more points also means more supports, and better load distribution.Originally posted by: drinkmorejava
Err, I suppose that works. It would probably be better to just properly support each vertical beam with diagonal members. Breaking them in half will just lead to more stress concentration points == more chances for something to break.
Either way decreases the effective length.
Fuck old ANSYS. Shitty interface, random-ass saves (where did my file go?) and NO UNDO WTFFFFFOriginally posted by: Jeff7
Ugh, my class got to that stuff in ANSYS just a week or two ago. Old ANSYS makes babies cry. Workbench is soooo much nicer. Granted, it's not quite as capable as the old ANSYS, but I don't think that'll last more than a few years.Originally posted by: drinkmorejava
err, how high off of the ground does it have to be? Just make a flat plate of toothpicks. If that doesn't work, I'd be happy to show you how to do a stress analysis for truss members 🙂
Cheaper option: Pontifex demo. 😉
Surprisingly, there are some videos of big bridges on Youtube.
I'm afraid I've never heard of Fluent (FLUENT?) until just now.
:laugh:Originally posted by: Howard
Also how much time he wants to spend.Originally posted by: drinkmorejava
Doesn't necessarily mean more supports. There?d be the same number of supports, just broken up into smaller sections. He'd essentially be gluing them back together anyway. I suppose he could offset each level.
I think we should define his needs first. Maybe, how much time does he want to spend?
*Sigh*Originally posted by: drinkmorejava
lol, if you're going to keep fixing my grammar, I'll just go to sleep, and you'll be all by yourself.
Originally posted by: DrPizza
Alternative idea that should win for creativity: Nothing is glued together. Use hotglue sticks as truss members & rivet them together with toothpicks. (Bore out pilot holes with a dremel). Act incredulous when you say "this isn't what you meant??"
