I have a WD 3.2GB Caviar 23200 HD that will not pass WD's diagnostic testing - it will fail with a 207 error code (SMART status failed before the media scan). I fdisked it and formatted it (w98) but formating would stop at 71% (have done this twice). Using WD's DLG 2.8, I wrote zeros (low-level formatted) the drive - it wrote to the entire drive and reported no errors. I'm at a stopping point!
The drive may be good but with a corrupted SMART monitoring ability that is interfering with its operation. The mobo I'm using doesn't have SMART monitoring ability so I don't use it. I want to disable SMART monitoring AT THE DRIVE and retest but haven't found a utility that will do this. Anyone have any links to a drive utility that might do this? Any other ideas? Help would be appreciated.
Buk
Buk
