V3LCR0
My recent water cooled computer had an accident today when one of the tubes popped out from the cpu water block.
I decided i will clean everything out and fix my computer's noise problem. Most of my fans run around ~100 cfm.
This can be very annoying over time, and can cause hearing loss.
My question to you guys is; Is there a way to connect two fans to one fan control, on a fan controller.
Does the amps on the fans matter? Do they need to be the same size? What color (red, yellow, or black) would i need to solder together in order for this to work? Is there anything else i should really know?
I have eight fans in my case, and i would like to control all eight with this.
http://www.newegg.com/Product/...x?Item=N82E16811999171
I have looked around the forums for info regarding this, but i believe me asking these questions would give me the best results.
Thanks.
Thanks.
