How to Connect 5.1 Speakers to Monitor ?
Aiden2k13
75
Hey guys, I am looking forward to buy a 24/27 inch monitor that has 1ms response time which is perfect for online gaming. I will be connecting my PS4 with it. But I want my speakers to give me sound and not my monitor. I have 5.1 speakers and I want those speakers to give me the audio.
The monitor will be having 3.5 mm port.
So, I will be connecting the monitor to my PS4 via HDMI cable but how will I connect those 5.1 speakers so that I get the sound from the speakers ?
SithSolo1
7,740
11
The 3.5mm port on the monitor is probably only an input port. Even if it is an output port it will only pass on a sterero(2.0) signal, not 5.1
What speakers do you have?
fralexandr
2,285
224
www.flickr.com
what speakers are you using?
the ps4 has optical out. On the off chance that your speakers have optical in (not common; found on things like the logitech z906/z5500), you can use an optical cable and set your ps4 to output audio through optical with dolby digital 5.1/dts encoding.
grimed
Easy just get something like a Denon E-300 use the HDMI out to connect to the monitor and the HDMI for the PS3.
Calibrate the speakers and enjoy
Aiden2k13
75
What kind of speaker system is it?
I am using Creative 5.1 Speakers.
But I have now connected my PS4 to my 40 inch 3D SMART LED TV and using its sound. But when I play online, I use SteelSeries 5HV2.
If you're gaming with a PS4, do you really need 1 ms response time?
Yes , kinda coz it reduces input lag. and I have bought BENQ XL2411T. :biggrin:
