Warm water or a spray cleaner they sell in any Office supply place for cleaning monitors and LCDs. NEVER spray the monitor - spray a cloth (soft cloth) then use it to clean the screen. You don't want liquids dripping inside.
In a pinch rubbing alchohol is usually safe, but I wouldn't risk it myself. NEVER use an ammonia based product. I've seen ammonia just peel the coating right off.
