how to clean a lcd
I just use a slightly damp cloth. If you meant Windex though, that's not a good idea as it will wipe off any coatings on the panel.
Originally posted by: xNIKx
can i just use a wet rag or windew and paper towel or do ineed a special product?
Do not use a paper towel unless you want scratch marks all over your nice LCD. I use a high quality micro fiber cloth and plain water. You can also look into buying an LCD cleaning kit, such as those sold at BestBuy or Staples.
A switchblade, doused with alcohol, lit, and moved up and down and across the screen in a serpentine fashion.
Now if you wish to clean just one liquid crystal diode then it's a whole different story.
I use paper towel and alcohol. No scratch 🙂 Guess the brand matters 😛
OT: Shouldn't it be 'an' LCD instead of 'a' LCD
Damp (distilled water if possible) lint-free cloth.
Yes, if the first part of the next word sounds like a vowel ("ell"), you use an.
ViewSonic reccomends water and clean cloth for their VX2025 LCDs. I know I got one and read the manual. I reccomend you read the manual to see what the manufacturer reccomends for your LCD. If you dont have a manual you can probably find it on the manufacturers website.
I used to use a damp paper towel, but that just didn't cut it once I got my NEC 20WMGX2 because of the glossy coating. Now I just use a microfiber cloth.
