3.8 Ghz is not enough...Mainly because I play EQ2 and it seems to be limited by my processor, yet at this clock I still lagg, but if I underclock my 5870s all the way my FPS doesn't budge. So I know its the CPU - I am also thining it is my mobo, since I built this computer right when the 955 came out I ordered the M4A79 Deluxe mobo (DDR2) so If I switched to the new Crosshair III or the newest M4 w/ DDR3 would that change anything?
try install a 32bit windows xp (clean install), dual boot into it, and run the game...might help w. squeezing more out of single core performance.
Using Hyper-V you'll experience a choppy slide show, if at all.now would there be a diff if I used hyper-v to virtualize 32 bit xp compared to installing it on a seperate partition?
lol, this brings up the story of last time I tried to dual boot, basically I corrupted both installs kernels and got stuck in the GRUB GUI...
before I try that I am going to remove windows 7 and revert back to server 2008...now would there be a diff if I used hyper-v to virtualize 32 bit xp compared to installing it on a seperate partition?
big difference... virtualization doesn't virtualize dx well.
if you really want to see how virtualization fails at dx, keep windows 7 and install "windows xp compatibility mode".
i'm pretty sure u'll be fine w. dual boot.. ms software get along w each other much better.
for corrupted kernels, just copy the newest version (win7) kernal and it should work fine.
