BlindBartimaeus
I just got a new barton and will do 11X200 at stock voltage. Ideally I would be at 12X200 when all said and done. At 1.8 volts it would not do it right out of the box. What would help this situation. Do you run it at a higher voltage for a few days then try again. Am I stuck at a 2.2 gig (3200pr)?? It has the AQXEA xpmw stepping and should do well. I have an SLK900 with a "pretty" LED fan on it. I should be able to go higher...any thoughts?
