Originally posted by: Budman
Nobody can tell you what timings YOU should use,every chip is different.
You can buy 2 identical sticks but they might be very different.
The best way is by trial and error.
set it at the fastest & then test with memtest to see if there's errors.
Now that's more helpful, thank you. What I was going for is the general what settings
should I be tweaking and what I should leave alone.
As it stands, I tried setting it to 2-2-2-5-2, and Windows comes back with a missing directory (odd). Changed it back to the more conservative settings, and it runs dandy. Unfortunately I don't have alot of time today to play with it. I'm wondering since the last BIOS update for my board enabled the 1/5 divider, whether or not it's worth running a 166MHz FSB.
-D
PS - Budman, thanks for refraining from trying to rip me down and spin me around with that last post. I'm really just looking for some honest help, especially where to start (and the manuals usually aren't very helpful, to me at least). With SDRAM, it was easy, just set it to 2-2-2 and see if it worked. With DDR, there's more (finnikey) settings that I don't know anything about.
