sciencetoy
- Oct 10, 2001
- 827
- 0
- 0
I do the taxes for a close friend who is in a similar situation. Just be warned, let the IRS do the calculating for the EIC. I have done the figures myself every year and I've never yet gotten the same numbers the IRS gets. There's a box you can check that says, let them figure the amount out.
I suggest that you get the forms and a book (from the library) and fill it out yourself, just so that you know what goes into it.
TurboTax is cool but doesn't figure the state EIC in my state - or at least it didn't used to.
The person who is head of household is the one who provides the most financial support. That would be the one with the larger income if you pretty much split expenses, or whoever can prove the larger support amount.
Good Luck
Good Luck
