Originally posted by: rdubbz420
rtfm.😛
Originally posted by: alien42
sportshift automatic tranny?
Originally posted by: GrammatonJP
Look in the service manual... usually 30k for a drain and fill
but drain and fill never gets out all of the fluid... so I do mine over a 2-3 week.. drain and fill 3 times...
someone people do the flush and fill but theres some danger associated to that from all the internet forums..
a proffesional flush is much more effective than even several drain and fills. Take it to a mechanic who knows what he's doing, not jiffy lube.
Originally posted by: OS
honda service manuals usually specifically state NOT to power flush their transmissions.
drain and fill for regular service. If it has not been serviced consistently, drain and fill, drive around a couple miles or so and then drain and fill again. That will remove atleast 2/3rds the fluid. Repeat one more time if you want almost all of it out.
edit, sorry this is for auto, the thread is for manual which i know nothing about.
It's even more confusing than that now. Dexclone coolant (extended life) comes in green now. Plus you have pink, yellow, red, (and purple?) coolants.Originally posted by: jupiter57
Auto. Trans fluid: Fluid & Filter change every 25-30K.
Coolant change: A: The "old style" green coolant: Every 3 years
Coolant change: B: The "new style" orange coolant: Every 5 years
I've seen tranny's go out even w/ the pros doing flushes. I wouldn't do it.Originally posted by: LordMorpheus
And most recommend the old style every 2 years.
Let me guess, you're over 50 years old?Originally posted by: funboy42
Manual tranny-never
Coolant about every 30K miles.
