How often do you really need to change your oil?
mooseracing
1,711
Originally posted by: crazySOB297
Originally posted by: Apex
Get the oil analyzed, then, know for sure.
^ this
Will save you money and headache.
Only way to go if you want a truthfull answer.
I'm a 2-3k person though. The 3 months thing has also been proven this year IIRC is the longest oil should be in an engine due to it breaking down because of the acids given off inside the engine.
DomS
Banned
Jul 15, 2008
1,678
Originally posted by: weeber
DomS,
Your car should have a very similar, if not identical, system to my '01 Monte Carlo. GM puts Oil Life systems on most if not all their recent cars. It should keep track of your mileage, time, and driving conditions (rpm, time at operating temperature, etc.) and lets you know when it's time to change the oil.
In my case, the oil light doesn't come on until 5,000-6,000 miles, and that's when I change it. Look at your manual, and see if your car has this. If it does, I would just change it when the light comes on, that's what it's designed for.
I didn't realize that, thank you very much!
SithSolo1
7,740
11
If that's the case I may get 1.5k out of every change if that.
I'm currently overdue millage wise(says every 3,750 but I'm 500 over) but I think the last time it was changed was back in June/July. :eek:
I do have an oil change scheduled for next week.
CU
2,415
51
My Colorado manual says when the oil life meter tells you to or atleast once a year. I think our Envoy says the same. My Colorado will almost make it a year before the light comes on.
Indyboy2
317
It all boils down to the type of oil used and the quality of the filtration system i go every 12k with amsoil syn engine oil in a turbocharged engine with no problems and could probably go more but thas what i do in a year
JDub02
6,209
every 5k miles with syn or semi-syn in my Mazda
every 3k miles with dino oil in my truck
randomlinh
linh.wordpress.com
^ this
only if you know what everything means...
Pretty tough not to, every report I have ever seen has a section stating the estimated life time left on the oil, amount of detergents left, etc.
How can that save money? I can change my oil for $20.
It saves it for the people doing crazy 2-3k oil changes. Gives them proof they are wasting money. Anyone changing like that is nuts. I do about 3 months or ~6k miles, give or take 500 depending on convenience.
dino or semi-syn(stock motorcraft) in the winter, syn in the summer. And that's with autocrossing, hence the syn in the summer (I'm a little paranoid). I got UOA's wondering how it affected the oil, and basically got my oil change times from that.
Elstupido
643
The service interval lights on my BMW, are based on gallons of fuel consumed in a given period of time. In other words the heavier the duty cycle, the more gallons consumed, the lesser the interval light.
On my current consumption, which is mainly highway driving, I can theoretically go between 12, and 15k before an oil change with fully syn. Realistically I would only go 7500 to 9500 miles. Now this is with a crankcase capacity of 8 quarts.
Depends on your driving habits.
chucky2
10,018
37
The only way, as previously mentioned, is to get a Used Oil Analysis (UOA) and make sure they give you at least a TBN reading...TAN is nice too.
Once you start getting into the 2-3 TBN range, you're oil has been mostly depleted of its ability to neutralize the acids that build up in the oil...at that point, you should change your oil and filter before you get to a TBN of 1.
The goal is to keep your oil fresh enough where the TBN stays higher, and the Insoluables (dirt and debris in the oil) stay low.
As also mentioned, water - especially for those in the cold climates - is a problem. Going for a long ride once a week is not a bad idea. Realize though that it can take upwards of 20 minutes for the engine oil (not the engine coolant, which is what your temp guage is measured off of) to get up to full operating temp...and that's what's needed to start burning off excess water.
Another way to extend the life of your oil is to avoid excessive idling - it dumps larger than normal amounts of gas into the oil as the vehicle is running rich....especially this time of year in the winter.
Probably the most popular oil analysis - but certainly not the only - on BITOG is Blackstone Laboratories. They'll send you a free test kit that you can USPS back to them for like under $2 USD. When you do that, you send them back a UOA sample and pay them about $30 USD. It's $30 USD for them as you'll need to pay the extra $10 USD for a TBN analysis, which tells you the life left in your oil.
If you drive the same, and use the same oil time every time, you can basically determine how long you can safely go between oil changes. It's also a nice thing to have if you plan on keeping your ride a long while, as you can see how the engine is wearing, if you have coolant leaks, if you have excess dirt ingestion, etc.
Blackstone Laboratories: Free Test Kit
Pretty interesting stuff once you get into it all...
Chuck
