The proper way to decock the gun is to put it in your mouth and pull the trigger
Looks like he decocked it perfectly; someone however needs to explain the difference between a decocker (such as found on a Sig Sauer) and a safety. Similar appearance, vastly different functions.
If he de-cocked it perfectly, it wouldn't have gone off. He tried to de-cock it 1911/revolver style, which is fine, but there's a reason you point it in a safe direction when you do that. Release the hammer too soon and you get a discharge. Hell strictly speaking it's supposed to be pointed in a safe direction at all times. Guy is an idiot.
I guess we can add you to the list of people who need an explanation of what a decocker is and how it differs from a safety. Trust me, if you actuate the decocker on a Sig Sauer P22x series pistol then squeeze the trigger, the weapon will fire.
http://en.wikipedia.org/wiki/Safety_(firearms)#Decocker
And I guess we can add you to the list of people who don't know where the decocker is on a Sig, because if you watch the video he didn't use it.
You must have better eyes than me then, because at the 0:11 mark or so he dropped the magazine, the release for which is immediately above the decocking lever; if it was in fact a Sig P22x pistol. The resolution isn't high enough to see definitively whether he depressed the decocker, and I can't see if the hammer is in the single-action or double-action position. Either way, you could at least be self-aware enough to correct your earlier statement that the weapon would not have gone off had he decocked it. If he pulled the trigger, it would have fired regardless if were a Sig.
I never said it wouldn't if he'd pulled the trigger afterwards, no correction required; and actually the mag release is significantly below the decocker and is a button as opposed to a lever. Given the nature of the decocker and the range/manner of motion required it's nearly impossible to accidentally actuate or mistake for a mag release.
What I'm seeing at 0:15 is his thumb on the cocked hammer and his finger in the trigger guard, the instant before the discharge. Indicates he was trying to do a traditional decock when it was in single action mode, didn't have enough of a hold on the hammer and released it too soon/too fast; while the gun was pointed in the most idiotic direction possible.
Correct. Also, this video demonstrates the proper way to safety check a gun:
http://www.youtube.com/watch?feature=player_profilepage&v=RLk7pDYLm0w#t=138s
1.Take your booger hooker off the bang switch. 2.Put it on safe dummy!
pretty much that^
