YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Download the quick hookup diagram here
http://www.onkyousa.com/model.cfm?m=HT-S6200&class=Systems&p=d
For the speaker wire that comes with the Onkyo unit, it should be pre-stripped at the ends and there should be 7 of them of various lengths. I'm not positive the wire is pre-stripped from that hookup diagram, but if it's not, you just need to strip off a little bit of the insulation on the ends.
It looks like the speakers have spring clips on them. For those, you just need to push the tabs back to make room for the speaker wire, and then you feed the speaker wire in and then push the tab back down... making sure that the metal contact on the speaker is touching the speaker wire.
Each speaker wire is made up of two strands. In order to make sure everything is "in phase", you need to get the polarity right on all the connections. The onkyo wire should have one strand labeled with a white stripe or something. Always connect the marked strand to the red connector point on each speaker.
On the receiver end, you have binding posts. For those, you unscrew the plastic knob at the back of the receiver. This will expose a threaded metal post at the back. Stick your speaker wire into the exposed gap you created by unscrewing the plastic knob. Tighten the plastic knob back down to make sure you get good contact with the wire and metal parts of the connector. Don't tighten it really hard.
Again, you need to get the phase / polarity right. The marked strand of speaker wire should connected to the colored connector for each pair of binding posts. The unmarked strand will go to the black connector for each pair of binding posts.
Does that make sense?
