How much smaller can chips go? [article]
extra
1,947
7
There's other materials that are supposedly suited to making faster cpus, like gallium arsenide, but I don't know much about that...perhaps one of our experts can give some info...
aphorism
41
the cost of masks is on a per transistor basis, unlike ic's where all transistors are made simultaneously. the cost of masks has been doubling for many years. a 65nm mask set is ~3million dollars, a 45nm mask set is ~6million, 32nm is 12million, etc.
also the number of masks is increasing because another metal layer is added every other process or so.
cbn
12,968
221
So the masks aren't really getting more expensive at smaller nodes. It is just that these smaller nodes often have more xtors?
I am getting this right?
For example, 3 million xtors on 65nm process would cost the same to mask as 3 million xtors on 32nm process?
Kakkoii
379
As partly said by someone before, when we reach the limit of lithography and silicon we will have to transition to carbon nanotube interconnects and graphene gates, which have amazing electrical properties that themselves will be able to increase processing power vastly, apart from the fact of the fab size shrink. Much headway has been made in the past few years in making chips with these.
Random articles on it:
http://en.wikipedia.org/wiki/Graphene#Electronic_properties
http://en.wikipedia.org/wiki/Graphene#Graphene_transistors
100Ghz graphene transistor made by IBM
http://www.technologyreview.com/computing/24482/?a=f
http://www.hplusmagazine.com/articles/toys-tools/graphene-next
http://gadgetophilia.com/graphene-carbon-nanotubes-promise-cheaper-more-powerful-electronic-devices/
But again, then we reach the physical limit of atoms themselves, so we must then work on fabricating in cheaper ways, developing better architectures and coding ways, and building chips that have layers upon layers of cores all interconnected. Until the day comes when quantum computing is capable at room temperature at an acceptable hardware size and cost. How fast that day comes is obviously unknown though. But we are making fast strides in that area also.
Campy
785
171
We definitely still have a long long way to go in computing. When one paradigm is exhausted we'll simply move on to another.
Kakkoii
379
There will never be a single atom transistor, and you can quote me on that. There are few places in engineering where I can say never, this is one of them.
To have a transistor as we use them, AT LEAST 3 atoms are necessary (Base, collector, emitter). And frankly, it is highly unlikely that we will get to the state of a tri-atom transistor (unless, somehow we create a chemical compound that transfers electrons like a transistor.)
Or how about make a transistor that operates in a completely different manner? Gotta think outside the box.
http://en.wikipedia.org/wiki/Ballistic_transistor
http://www.rochester.edu/news/show.php?id=2585
"Due to its high electronic quality, graphene has also attracted the interest of technologists who see them as a way of constructing ballistic transistors."
But yeah, of course no single-atom transistor.
Cogman
10,286
145
Even these involve at least 2 atoms. While they may be different, they rely on having the two or more atoms pinch/unpinch the flow of electrons.
Again, no single atom transistor will ever exist.
Kakkoii
379
Uh, I don't think you read what I said at the bottom of the post..
"But yeah, of course no single-atom transistor."
and I wouldn't say they pinch/unpinch the flow. They merely direct the flow down one path or another using magnetism.
aphorism
41
yes, processing/repairing the mask design is a lot of the cost but there are some costs related to materials and other issues.
for example intel's 22nm node uses computational lithography. according to ACML it requires a sustained 10tflops for 24hours to process one layer. on 22nm this could be for only critical layers but in future processes it might be all of them. someone here could probably tell you the costs of operating/buying/maintaining several 10tflop machines, but that's not my thing.
also there are other ways of enhancing resolution. such as optical proximity correction or phase shift masks. all of these cost more but continue scaling.
