how much power is enough?
Shimmishim
7,504
for a p4 setup.... let's say... pushing a 1.6a or 1.8a to 2.4 ghz range....
is 300W enough or will i need a 400W maybe?
THUGSROOK
11,847
i use a 431W enermax. all my voltages are rock steady at all times. (on my new moboard that is)
if you already have a 300w go ahead and try it. if you have to buy something tho, may as well get a good 350+W.
Migroo
4,488
9
<< grrr.. my system is gonna cost more than i thought at this rate!!! :p >>
Its always the case :(
Dre
2,247
4
I've heard of people using 300watts for northwood systems. I personally use 350watts on my northwood
rexfalk
171
Murphey's Law of Projects...."Everything costs more and takes longer than origionally intended"
:D
Shimmishim
7,504
<< Murphey's Law of Projects...."Everything costs more and takes longer than origionally intended"
:D
hehehe.... true dat.... :)
