Playing a new MMO and things are a bit sluggish. A friend says he doesnt have these problems so I'm assuming my PC is a bit older than I'd like to admit.
I play at 1920x1200 on a 25" monitor.
So, will just a new Video card hold me over and give me a significant, noticeable improvement? Video Card + Ram? Card, RAM and new HDD? Or do i just need to start over.
Current system:
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor BX80570E8400
EVGA 512-P3-N845-AR GeForce 8800GTS (G92) KO 512MB 256-bit
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Corsair HX 520 W PS
Get a cooler master hyper 212+
http://www.newegg.com/Product/Produc...-065-_-Product
Overclock your CPU 3.8-4.0 ghz. If your not sure how I could help. I post from work and have ample time to mess around. I could help you get a nice stable 3.8-4ghz out of your current CPU which should hold you over for awhile.
As far as gpu goes I'd go with this. More performance than the 460 or 6870 for $200 after rebates. I don't think you'd find anymore gpu for the money anywhere.
http://www.newegg.com/Product/Produc...-883-_-Product
For under $250 you could have a very capable gaming machine.
I'll give the overclocking a shot. As far as the GPU this is where it gets confusing. So a 5870 is superior to a 6870?
EDIT: Ok I'm reading an article in Anandtech that explains it. Kinda. Just to clarify though:
SAPPHIRE 100281-3SR Radeon HD 5870 (Cypress XT) 1GB 256-bit DDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
that 5870 you linked with outperform this?
http://www.newegg.com/Product/Produc...82E16814102909
SAPPHIRE 100314SR Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
One thing to consider. Although 5870 is faster than 6870, it is close in performance, but 6870 has some additional features. Main things added are lower power usage as well as HD3d capabilities.
It is also faster in crossfire if you get a second card in the future compared to 5870 CF.
Has anyone actually checked whether Rift runs better on nVidia? I just lazied out on my first post suggesting nVidia because this game has the TWIMTBP logo, and I couldn't find a benchmark of it within 10 seconds using Google. OP also said you'll be playing other games in the future, may we ask which ones if you know?
Current system:
Corsair HX 520 W PS
Heres what I think you should do:
Newegg combo deal:
AMD Athlon II X4 645 Propus 3.1GHz Socket AM3 95W Quad-Core
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
168$ (after Mail in rebate)
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit
39.99$
~208$ (for MB,CPU,RAM)
HIS H695F2G2M Radeon HD 6950 2GB 256-bit GDDR5 PCI
259$ (after MIR)
total 467$
what do you get for it?
Athlon II x4 3.1GHz you oc to run @4.0GHz
4gb of DDR3 dual channel ram
6950 2gb, that you bios flash to a 6970 + overclocked (near 580 perf.)
The althon II x4 is very close to the phenoms in performance, and its cheap... getting 4 cores running 4GHz for its price isnt bad.
the value you get out of unlocking a 6950 -> 6970 is good, and then overclocking it, and your basically around a stock 580, for only 259$.
That should make a very decent gameing platform.
The only good advice given below is to get the HD 6950 .. unlocking the Athlon II depends on luck and is a sidegrade at best. Athlon II X3s are not guaranteed to unlock. Nor are they as fast as the OP's C2D.
If you want to say "Wow!" from your system, upgrade your videocard
if you want :\, upgrade your CPU and platform
First, upgrade the video card. Then sit back and play some games and then decide if you want a quad-core.
I am going to go ahead and agree with happy_medium here, if you have no immediate plans to upgrade your monitor, the GTX 560 is probably the best card for you. At your resolution the performance difference is negligible and although you can unlock a 6950 to a 6970, the GTX 560 can OC to speeds that will match a 6970/GTX 570 anyways. Pretty much a wash, just get the cheapest one.I'd grab a brand new Evga gtx560 for 215$ shipped off this guy first.
http://forums.anandtech.com/showthread.php?t=2140278
If so I'd guess it's safe to say I'm being CPU limited?
Just buy the GPU first, if you feel like you still haven't seen as big a jump as you wanted then upgrade the other components in the system.
The hardware you have now should be able to do better than that. It's easier to tell whether you are CPU or GPU limited by changing a game setting that affects the GPU from off/low to max than by OCing.
If Rift is like WoW, then the HDD can actually make a huge playability difference as well. That Caviar blue isn't too old, but if you can use the extra storage, I highly recommend the Samsung F3 1TB, or consider a small SSD if you don't need more space but just play a couple games primarily and want max speed.
