How much longer will this cpu last?
red_222
46
I built my current computer back in 2009, and have been happy with the performance since, but im not sure how long my cpu will last me. What do you guys think? I play most current games.
System:
Intel Core i7 980 6 Core @ 4ghz 1.275v
12gb Corsair DDR3 1600 RAM
Asus P6T Mobo
BFG 1000W PSU (Too bad they went out of business 3 years ago :( )
Just got a AMD R9 290 Vid card.
take the life of the current 3930/3960 and add those years to your 980 and thats how much longer it will be relevant. I honestly think the i7 980x is a better cpu IMO than the 3930/3960 group.
escrow4
3,339
122
I'd still take the IPC and architectural improvements of a 4770 over older hexa cores unless you really need those cores. Next gen consoles will use more cores but PC's are not consoles. Standard sloppy coding and ports and I wouldn't be surprised if single threaded grunt will still remain critical.
JIM2003
8
So I got my CPU to 4.5hz, but if I enable Hyperthreading it will crash occasionally. Do you guys think I should just leave HT off, I don't want to up my vcore past 1.4v. 6 cores without HT should be enough right? :D
adnank77
125
I'm having kinda similar system .. As far as most games you play are GPU dependant and as far as you have a good GPU like R9-290 then no need to upgrade ..
Mostly I'll hold up until I see some benchmarks of Haswell-E when it comes out .. Note that lately focus of intel is not much on increasing perofrmance (due ot lack of serious competition there), instead, they focus on mobile related matters like power consumption and so .. Competition is much higher there ..
Nov 26, 2005
15,197
403
I would back it off to 4.4Ghz and leave HT off to avoid any corrupt files, IF the machine is critical to daily use.
Haider
63
I think you are barking up the wrong tree. The CPU is fine. I'm running an i-760@3.6GHz and 7950 Vapor-X@1050 with power limit set to +20% in Trixx. As I increase the speed of the GPU the faster games become. I think you want to concentrate on overclocking your graphics card rather than anything else...
Ajay
16,094
8,116
Very nice OC!
I agree, better safe than sorry. For games and typical desktop use, I don't think there is any need for HT.
Dec 30, 2004
12,553
Turn on hyperthreading and turn off your 4.5ghz overclock. You don't need the overclock. The hyperthreading and 4ghz will keep you running long time. :)
The CPUs in PS4/XBONE much slower than yours.
Jacky60
1,123
I reckon you could easily get a couple more years out of it. I only just upgraded from my 920 at 4Ghz to 4770K at 4.8. Haswell E does seem promising though and will probably be next worthwhile upgrade for you.
