How much engine damage can you do if you leave the oil cap off?
steppinthrax
3,990
So I added about a quart of oil to my Camry. I left the cap on the top of the battery and closed the hood. Drove around with it for a few days and noticed a oil smell but wasn't quite sure where it was coming from. I thought maybe that some oil might have gotten on the exhaust and was burning. I popped my hood and realized my stupid mistake. I replaced the cap and test the oil level (good level at full). I didn't notice any oil spilled out or on the inside of the hood etc.
Kushina
1,598
Should be fine, I don't know for as a fact but I'm pretty sure the oil pump removes air pockets if they are there as the oil is pumped into the engine area. Take the cap off and see if you find any debree that you can take out, I'd say do another drain and fill just to clean it out incase.
Take what I say with a grain of salt I'm not an engineer, just a guy that does alot of DIY and looks into various components and how they work as I go along.
smackababy
27,024
79
86
If you're not losing oil from it, I would think the worst thing that could happen is contamination. I'd check the oil level and maybe get a chance if you're worried about anything getting inside.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
121
Replace oil cap. Check oil level. If low, add.
We're all guilty of this at least once in our lives.
Reactions: Mopar4life
Pulsar
5,224
306
What Ferzerp said. The oil pickup tube in the oil pan usually has a strainer on it, and remember there's an oil filter for a reason.
Even a little moisture and dirt won't do much.
davidgraef
I did the same thing to my Echo and the check engine light came on and the computer gave me error code P0171 - are they related with the air getting in? Is it safe to drive and the system will work the air pockets out?
Thanks in advance,
David Graef
BurnItDwn
26,339
1,848
So, steppinthrax, still got the same car?
How's it running? did you wind up having any problems with the engine over the last 4 years?
steppinthrax
3,990
Lol
Wow this is an old thread. Yeah it has 208 miles and looks ragged to hell. In the market for a Prius. But nothing wrong with the Camry other than cosmetic and general age.
Sent from my LM-Q610(FGN) using Tapatalk
Reactions: BurnItDwn
BurnItDwn
26,339
1,848
Lol
Nice, those things are built very well. Good luck on your Prius hunt.
Joebklyn
8
I once checked the oil in my car before going on a 300 mile trip. I forgot to put the cap on. Got off the highway, 1st stop of the trip and I smelled it. Drove to an auto parts store. I was 1.5qts low, filled it to the proper level and got a new cap. No damage except ego.
